Saltar al contenido principal
Google Pixel Slate Rear-Facing Camera Replacement
Qué necesitas
  1. Google Pixel Slate Rear-Facing Camera Replacement, Screen: paso 1, imagen 1 de 3 Google Pixel Slate Rear-Facing Camera Replacement, Screen: paso 1, imagen 2 de 3 Google Pixel Slate Rear-Facing Camera Replacement, Screen: paso 1, imagen 3 de 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Rear-Facing Camera Replacement: paso 2, imagen 1 de 3 Google Pixel Slate Rear-Facing Camera Replacement: paso 2, imagen 2 de 3 Google Pixel Slate Rear-Facing Camera Replacement: paso 2, imagen 3 de 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: paso 3, imagen 1 de 3 Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: paso 3, imagen 2 de 3 Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: paso 3, imagen 3 de 3
    • Use a T2 Torx screwdriver to remove the two black 2mm screws holding down the square plate.
    • Use the Nylon Tipped Tweezers to lift the metal plate.
  4. Google Pixel Slate Rear-Facing Camera Replacement: paso 4, imagen 1 de 3 Google Pixel Slate Rear-Facing Camera Replacement: paso 4, imagen 2 de 3 Google Pixel Slate Rear-Facing Camera Replacement: paso 4, imagen 3 de 3
    • Use a T3 Torx screwdriver to remove the two yellow and grey 3mm screws from the L-shaped plate.
    • Use the Nylon Tipped Tweezers to lift the plate from the device.
  5. Google Pixel Slate Rear-Facing Camera Replacement: paso 5, imagen 1 de 2 Google Pixel Slate Rear-Facing Camera Replacement: paso 5, imagen 2 de 2
    • Gently pull upwards to remove the camera.
Conclusión
Una persona más ha completado esta guía.
Spencer Alonge
Miembro Desde 04/18/19
648 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S2-G5, Maness Spring 2019 Miembro de Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 520
