Saltar al contenido principal
Google Pixel C Headphone Jack Replacement
Qué necesitas
  1. Google Pixel C Headphone Jack Replacement, Screen: paso 1, imagen 1 de 1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Headphone Jack Replacement: paso 2, imagen 1 de 2 Google Pixel C Headphone Jack Replacement: paso 2, imagen 2 de 2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
  3. Google Pixel C Headphone Jack Replacement: paso 3, imagen 1 de 2 Google Pixel C Headphone Jack Replacement: paso 3, imagen 2 de 2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
  4. Google Pixel C Headphone Jack Replacement: paso 4, imagen 1 de 2 Google Pixel C Headphone Jack Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
  5. Google Pixel C Headphone Jack Replacement, Headphone Jack: paso 5, imagen 1 de 1
    • Orient the device so that the headphone jack is in the bottom right corner.
  6. Google Pixel C Headphone Jack Replacement: paso 6, imagen 1 de 2 Google Pixel C Headphone Jack Replacement: paso 6, imagen 2 de 2
    • Remove the two 3.5mm Phillips #000 screws.
  7. Google Pixel C Headphone Jack Replacement: paso 7, imagen 1 de 1
    • Locate and remove the two 2.5mm Phillips #000 screws on either side of the wire coil.
  8. Google Pixel C Headphone Jack Replacement: paso 8, imagen 1 de 2 Google Pixel C Headphone Jack Replacement: paso 8, imagen 2 de 2
    • Detach the red and black cable using a narrow spudger.
  9. Google Pixel C Headphone Jack Replacement: paso 9, imagen 1 de 2 Google Pixel C Headphone Jack Replacement: paso 9, imagen 2 de 2
    • Detach the cable connecting to the headphone jack.
  10. Google Pixel C Headphone Jack Replacement: paso 10, imagen 1 de 2 Google Pixel C Headphone Jack Replacement: paso 10, imagen 2 de 2
    • Lift the headphone jack, coiled wire, and cable, peeling the adhesive back.
    • Reassembly will require adhesive to ensure that the components are secured to the device.
Conclusión
Deborah Iwakiri
Miembro Desde 04/25/17
522 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S21-G4, Livingston Spring 2017 Miembro de Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 963
