Saltar al contenido principal
Google Pixel 4 Motherboard Replacement
Qué necesitas
  1. Google Pixel 4 Motherboard Replacement, Remove the SIM card tray: paso 1, imagen 1 de 3 Google Pixel 4 Motherboard Replacement, Remove the SIM card tray: paso 1, imagen 2 de 3 Google Pixel 4 Motherboard Replacement, Remove the SIM card tray: paso 1, imagen 3 de 3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 Motherboard Replacement, Heat the back panel glass: paso 2, imagen 1 de 1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4 Motherboard Replacement, Apply a suction cup: paso 3, imagen 1 de 2 Google Pixel 4 Motherboard Replacement, Apply a suction cup: paso 3, imagen 2 de 2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 Motherboard Replacement, Insert an opening pick: paso 4, imagen 1 de 2 Google Pixel 4 Motherboard Replacement, Insert an opening pick: paso 4, imagen 2 de 2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 Motherboard Replacement, Begin to slice the adhesive: paso 5, imagen 1 de 3 Google Pixel 4 Motherboard Replacement, Begin to slice the adhesive: paso 5, imagen 2 de 3 Google Pixel 4 Motherboard Replacement, Begin to slice the adhesive: paso 5, imagen 3 de 3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 Motherboard Replacement, Slice the lefthand-side adhesive: paso 6, imagen 1 de 1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 Motherboard Replacement: paso 7, imagen 1 de 2 Google Pixel 4 Motherboard Replacement: paso 7, imagen 2 de 2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 Motherboard Replacement: paso 8, imagen 1 de 2 Google Pixel 4 Motherboard Replacement: paso 8, imagen 2 de 2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 Motherboard Replacement, Slice righthand-side adhesive: paso 9, imagen 1 de 1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 Motherboard Replacement: paso 10, imagen 1 de 3 Google Pixel 4 Motherboard Replacement: paso 10, imagen 2 de 3 Google Pixel 4 Motherboard Replacement: paso 10, imagen 3 de 3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Google Pixel 4 Motherboard Replacement, Slice the top-side adhesive: paso 11, imagen 1 de 2 Google Pixel 4 Motherboard Replacement, Slice the top-side adhesive: paso 11, imagen 2 de 2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 Motherboard Replacement, Lift up the back panel: paso 12, imagen 1 de 3 Google Pixel 4 Motherboard Replacement, Lift up the back panel: paso 12, imagen 2 de 3 Google Pixel 4 Motherboard Replacement, Lift up the back panel: paso 12, imagen 3 de 3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 Motherboard Replacement: paso 13, imagen 1 de 2 Google Pixel 4 Motherboard Replacement: paso 13, imagen 2 de 2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before re-sealing the back panel. Be sure to power your phone back down completely before you continue working.
  14. Google Pixel 4 Motherboard Replacement, Disconnect the battery: paso 14, imagen 1 de 1
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the five T3 Torx screws securing the battery connector shield:
    • Four 4.0 mm screws
    • One 2.1 mm screw
  15. Google Pixel 4 Motherboard Replacement: paso 15, imagen 1 de 2 Google Pixel 4 Motherboard Replacement: paso 15, imagen 2 de 2
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 Motherboard Replacement: paso 16, imagen 1 de 2 Google Pixel 4 Motherboard Replacement: paso 16, imagen 2 de 2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Google Pixel 4 Motherboard Replacement: paso 17, imagen 1 de 2 Google Pixel 4 Motherboard Replacement: paso 17, imagen 2 de 2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 Motherboard Replacement, Disconnect the back panel connector: paso 18, imagen 1 de 1
    • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
  19. Google Pixel 4 Motherboard Replacement: paso 19, imagen 1 de 2 Google Pixel 4 Motherboard Replacement: paso 19, imagen 2 de 2
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 Motherboard Replacement: paso 20, imagen 1 de 2 Google Pixel 4 Motherboard Replacement: paso 20, imagen 2 de 2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  21. Google Pixel 4 Motherboard Replacement, Remove the back panel: paso 21, imagen 1 de 1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
  22. Google Pixel 4 Motherboard Replacement, Front Camera and Sensor Assembly: paso 22, imagen 1 de 1
    • Use a T3 Torx driver to remove the four 4 mm screws securing the camera connector cover.
  23. Google Pixel 4 Motherboard Replacement: paso 23, imagen 1 de 3 Google Pixel 4 Motherboard Replacement: paso 23, imagen 2 de 3 Google Pixel 4 Motherboard Replacement: paso 23, imagen 3 de 3
    • Using a pair of tweezers, tilt the camera cover up and slide it out of the retaining slot on the upper right corner of the phone to remove.
  24. Google Pixel 4 Motherboard Replacement, Disconnect the camera and sensor connectors: paso 24, imagen 1 de 3 Google Pixel 4 Motherboard Replacement, Disconnect the camera and sensor connectors: paso 24, imagen 2 de 3 Google Pixel 4 Motherboard Replacement, Disconnect the camera and sensor connectors: paso 24, imagen 3 de 3
    • Using the pointed end of a spudger, pry the camera and sensor connectors straight up from the motherboard.
  25. Google Pixel 4 Motherboard Replacement: paso 25, imagen 1 de 2 Google Pixel 4 Motherboard Replacement: paso 25, imagen 2 de 2
    • Disconnect the laser module connector.
  26. Google Pixel 4 Motherboard Replacement, Remove the front camera and sensor assembly: paso 26, imagen 1 de 1
    • Use a T3 Torx driver to remove the two 2.4 mm screws securing the front camera and sensor assembly.
  27. Google Pixel 4 Motherboard Replacement: paso 27, imagen 1 de 3 Google Pixel 4 Motherboard Replacement: paso 27, imagen 2 de 3 Google Pixel 4 Motherboard Replacement: paso 27, imagen 3 de 3
    • Use a pair of tweezers to remove the front camera and sensor assembly.
  28. Google Pixel 4 Motherboard Replacement, Motherboard: paso 28, imagen 1 de 1
    • Remove the two T3 Torx screws securing the vibration motor shield:
    • One 4.2 mm screw
    • One 4.4 mm shouldered screw
  29. Google Pixel 4 Motherboard Replacement: paso 29, imagen 1 de 2 Google Pixel 4 Motherboard Replacement: paso 29, imagen 2 de 2
    • Use a pair of tweezers to remove the vibration motor shield.
  30. Google Pixel 4 Motherboard Replacement, Disconnect the motherboard press connectors: paso 30, imagen 1 de 3 Google Pixel 4 Motherboard Replacement, Disconnect the motherboard press connectors: paso 30, imagen 2 de 3 Google Pixel 4 Motherboard Replacement, Disconnect the motherboard press connectors: paso 30, imagen 3 de 3
    • Use the pointed end of a spudger to disconnect the two rear-facing camera connectors from the motherboard.
  31. Google Pixel 4 Motherboard Replacement: paso 31, imagen 1 de 3 Google Pixel 4 Motherboard Replacement: paso 31, imagen 2 de 3 Google Pixel 4 Motherboard Replacement: paso 31, imagen 3 de 3
    • Disconnect the side buttons connector from the motherboard.
    • Disconnect the earpiece speaker connector from the motherboard.
  32. Google Pixel 4 Motherboard Replacement: paso 32, imagen 1 de 3 Google Pixel 4 Motherboard Replacement: paso 32, imagen 2 de 3 Google Pixel 4 Motherboard Replacement: paso 32, imagen 3 de 3
    • Disconnect the left grip sensor connector from the motherboard.
    • Disconnect the charge port connector from the motherboard.
  33. Google Pixel 4 Motherboard Replacement: paso 33, imagen 1 de 3 Google Pixel 4 Motherboard Replacement: paso 33, imagen 2 de 3 Google Pixel 4 Motherboard Replacement: paso 33, imagen 3 de 3
    • Disconnect the display connector from the motherboard.
    • Disconnect the right grip sensor connector from the motherboard.
  34. Google Pixel 4 Motherboard Replacement, Disconnect the antennas: paso 34, imagen 1 de 2 Google Pixel 4 Motherboard Replacement, Disconnect the antennas: paso 34, imagen 2 de 2
    • Use a pair of tweezers to grip the metal clip and pull the connector straight up off of the motherboard
    • You can also a spudger and pry up gently to unclip the bottom antenna connector from the motherboard.
  35. Google Pixel 4 Motherboard Replacement: paso 35, imagen 1 de 2 Google Pixel 4 Motherboard Replacement: paso 35, imagen 2 de 2
    • Disconnect the bottom microphone connector from the motherboard.
  36. Google Pixel 4 Motherboard Replacement: paso 36, imagen 1 de 3 Google Pixel 4 Motherboard Replacement: paso 36, imagen 2 de 3 Google Pixel 4 Motherboard Replacement: paso 36, imagen 3 de 3
    • Gently pry back—but don't remove—the two battery adhesive pull tabs lightly adhered to the motherboard.
  37. Google Pixel 4 Motherboard Replacement, Remove the motherboard: paso 37, imagen 1 de 2 Google Pixel 4 Motherboard Replacement, Remove the motherboard: paso 37, imagen 2 de 2
    • Using a spudger, pivot the top end of the motherboard up and out of the phone's frame.
  38. Google Pixel 4 Motherboard Replacement: paso 38, imagen 1 de 3 Google Pixel 4 Motherboard Replacement: paso 38, imagen 2 de 3 Google Pixel 4 Motherboard Replacement: paso 38, imagen 3 de 3
    • Slowly lift out the motherboard, being careful not to snag any ribbon cable connectors.
    • The rear-facing camera module connectors loop around the motherboard, and the camera module is not secured to the phone, so it may lift out with the motherboard during this step.
    • Completely remove the motherboard.
    • When removing the motherboard, the small rubber bottom microphone cover may fall off. Don't lose it.
    • When reinstalling the motherboard, check that no ribbon cable connectors are caught underneath.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 personas más completaron esta guía.
Carsten Frauenheim
Miembro Desde 03/10/20
113,672 Reputación
338 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
4 comentarios
please remove the edit capability on the page for users like me, this should be reserved to official team members of ifixit. Or else this will violate the integrity of the content and thus allowing for misuse.
Rohit Parchuri - Contestar
Hi Rohit, we appreciate your concern for the posted content, but the edit capability is a part of our wiki-based ethos. I'm linking to our "Getting Started with Wikis," this should give you a better understanding of how our site functions. Don't hesitate to reach out if you have any other questions or concerns.
Kris Rodriguez - Contestar
Hi, I am looking to replace my Pixel 4 motherboard and really appreciate the detailed guidance. However, I noticed that the motherboard replacement part is not offered through iFixit. Do you have a recommended genuine part supplier?
Thanks,
Patrick
Patrick Fletcher - Contestar
lose face id function after replace motherboard?
Andres Motta - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 29
Ultimos 30 días: 143
Todo El Tiempo: 6,457
