Saltar al contenido principal
Google Pixel 3 XL Partial Motherboard Separation
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Google Pixel 3 XL Partial Motherboard Separation, Remove one loudspeaker screw: paso 1, imagen 1 de 1
    • Remove the 4 mm long T3 screw securing the top-right corner of the loudspeaker.
    • Removing this screw will give you slightly more wiggle room when removing the motherboard.
  2. Google Pixel 3 XL Partial Motherboard Separation, Remove the button array connector bracket: paso 2, imagen 1 de 1
    • Remove the two 3 mm long T3 screws securing the button array connector bracket.
  3. Google Pixel 3 XL Partial Motherboard Separation: paso 3, imagen 1 de 1
    • Remove the button array connector bracket.
  4. Google Pixel 3 XL Partial Motherboard Separation, Disconnect the earpiece speaker: paso 4, imagen 1 de 2 Google Pixel 3 XL Partial Motherboard Separation, Disconnect the earpiece speaker: paso 4, imagen 2 de 2
    • Use the point of a spudger to pry up and disconnect the earpiece connector from its motherboard socket.
    • Carefully remove the connector pad surrounding the earpiece socket.
  5. Google Pixel 3 XL Partial Motherboard Separation, Disconnect the motherboard connectors: paso 5, imagen 1 de 1
    • Use the point of a spudger to pry up and disconnect the following:
    • Microphone connector
    • Button array connector
    • Earpiece connector (should already be disconnected)
  6. Google Pixel 3 XL Partial Motherboard Separation: paso 6, imagen 1 de 2 Google Pixel 3 XL Partial Motherboard Separation: paso 6, imagen 2 de 2
    • Charging coil connector
    • Left squeeze sensor connector
    • Display connector
    • Right squeeze sensor connector
    • Loudspeaker connector
    • USB-C port connector
  7. Google Pixel 3 XL Partial Motherboard Separation, Remove the motherboard screws: paso 7, imagen 1 de 1
    • Remove the two 3 mm long T3 screws securing the motherboard.
  8. Google Pixel 3 XL Partial Motherboard Separation, Loosen the motherboard: paso 8, imagen 1 de 3 Google Pixel 3 XL Partial Motherboard Separation, Loosen the motherboard: paso 8, imagen 2 de 3 Google Pixel 3 XL Partial Motherboard Separation, Loosen the motherboard: paso 8, imagen 3 de 3
    • Insert the point of a spudger underneath the motherboard, near the rear-facing camera module.
    • Pry up gently to loosen the motherboard from its recess.
    • If the motherboard is not budging, make sure you have disconnected all the connectors.
    • The motherboard has to squeeze past the earpiece speaker cable. If too much pressure is put on the earpiece cable, the earpiece speaker will pop open. You can prevent this by pressing on the earpiece module with a finger while you maneuver the motherboard out.
    • If the earpiece speaker pops open (as shown in the third photo of this step), carefully align and press the module back in place.
  9. Google Pixel 3 XL Partial Motherboard Separation: paso 9, imagen 1 de 3 Google Pixel 3 XL Partial Motherboard Separation: paso 9, imagen 2 de 3 Google Pixel 3 XL Partial Motherboard Separation: paso 9, imagen 3 de 3
    • Don't attempt to remove the motherboard from the phone. It's still attached to the phone.
    • While you perform this step, take care to keep slack on the antenna cables attached to the bottom leg of the motherboard.
    • Lift the top half of the motherboard slightly to clear the board from its recess.
    • Twist the left edge of the board over and out of the phone and rest the board on the right edge of the phone.
Conclusión
3 personas más completaron esta guía.
Arthur Shi
Miembro Desde 01/03/18
249,876 Reputación
503 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,732 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 802
