Saltar al contenido principal
Google Home Mute Button Switch Replacement
Qué necesitas
  1. Google Home Mute Button Switch Replacement, Interconnect Cable: paso 1, imagen 1 de 3 Google Home Mute Button Switch Replacement, Interconnect Cable: paso 1, imagen 2 de 3 Google Home Mute Button Switch Replacement, Interconnect Cable: paso 1, imagen 3 de 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Mute Button Switch Replacement: paso 2, imagen 1 de 1
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Mute Button Switch Replacement, Mute Button Switch: paso 3, imagen 1 de 2 Google Home Mute Button Switch Replacement, Mute Button Switch: paso 3, imagen 2 de 2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Mute Button Switch Replacement: paso 4, imagen 1 de 2 Google Home Mute Button Switch Replacement: paso 4, imagen 2 de 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
Conclusión
Una persona más ha completado esta guía.
Gabe Hyun
Miembro Desde 04/17/18
826 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S24-G11, Maness Spring 2018 Miembro de Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 889
