Saltar al contenido principal
Google Home Motherboard Replacement
Qué necesitas
  1. Google Home Motherboard Replacement, Interconnect Cable: paso 1, imagen 1 de 3 Google Home Motherboard Replacement, Interconnect Cable: paso 1, imagen 2 de 3 Google Home Motherboard Replacement, Interconnect Cable: paso 1, imagen 3 de 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Motherboard Replacement: paso 2, imagen 1 de 1
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Motherboard Replacement, Mute Button Switch: paso 3, imagen 1 de 2 Google Home Motherboard Replacement, Mute Button Switch: paso 3, imagen 2 de 2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Motherboard Replacement: paso 4, imagen 1 de 2 Google Home Motherboard Replacement: paso 4, imagen 2 de 2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
  5. Google Home Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 Google Home Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
  6. Google Home Motherboard Replacement: paso 6, imagen 1 de 2 Google Home Motherboard Replacement: paso 6, imagen 2 de 2
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
Conclusión
3 personas más completaron esta guía.
Maya Wharton
Miembro Desde 04/17/18
175 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S24-G11, Maness Spring 2018 Miembro de Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Miembros
5 Guías creadas
2 comentarios
Where can one purchase a replacement motherboard?
Jim Pflasterer - Contestar
Most likely the only place to do so would be through contacting Google, as there is no parts sold at retail, only full units
Nick Bergstrom -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 3,152
