Introducción
This guide involves removing the o-ring from around the casing, unscrewing the casing, and unscrewing the motherboard from the case.
Qué necesitas
Pull off the Google Home’s magnetically attached base and set it aside.
Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
After all four screws are out, pop the lid off the device to open the capsule.
Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
3 personas más completaron esta guía.
2 comentarios
Where can one purchase a replacement motherboard?
Most likely the only place to do so would be through contacting Google, as there is no parts sold at retail, only full units
