Saltar al contenido principal
Google Home Mini USB Power Port Replacement
Qué necesitas
  1. Google Home Mini USB Power Port Replacement, Google Home Mini Disassembly: paso 1, imagen 1 de 1
    • Place device on a flat surface.
  2. Google Home Mini USB Power Port Replacement: paso 2, imagen 1 de 1
  3. Google Home Mini USB Power Port Replacement: paso 3, imagen 1 de 1
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  4. Google Home Mini USB Power Port Replacement: paso 4, imagen 1 de 1
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
  5. Google Home Mini USB Power Port Replacement: paso 5, imagen 1 de 1
    • Pull the ribbon cable off.
  6. Google Home Mini USB Power Port Replacement, USB Power Port: paso 6, imagen 1 de 2 Google Home Mini USB Power Port Replacement, USB Power Port: paso 6, imagen 2 de 2
    • Remove the three 5.3mm T6 Torx screws from the board.
  7. Google Home Mini USB Power Port Replacement: paso 7, imagen 1 de 2 Google Home Mini USB Power Port Replacement: paso 7, imagen 2 de 2
    • Remove the black metal plate from the board.
  8. Google Home Mini USB Power Port Replacement: paso 8, imagen 1 de 2 Google Home Mini USB Power Port Replacement: paso 8, imagen 2 de 2
    • Remove the board.
Conclusión
9 personas más completaron esta guía.
Mia Sulaiman
Miembro Desde 05/21/18
1,032 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G4, Harley Spring 2018 Miembro de IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
7 Miembros
5 Guías creadas
8 comentarios
Where I can buy micro USB PCB ?
so_ang - Contestar
Planet Carl - Contestar
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Wolve 8383 - Contestar
Has anyone had any luck buying a replacement part?
Caitlin Barnum - Contestar
Just broke mine :-(
Is anyone managed to find a place to buy one?
Jim - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 20
Ultimos 30 días: 65
Todo El Tiempo: 6,150
