Saltar al contenido principal
Google Home LED Board Replacement
Qué necesitas
  1. Google Home LED Board Replacement, Interconnect Cable: paso 1, imagen 1 de 3 Google Home LED Board Replacement, Interconnect Cable: paso 1, imagen 2 de 3 Google Home LED Board Replacement, Interconnect Cable: paso 1, imagen 3 de 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home LED Board Replacement: paso 2, imagen 1 de 1
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home LED Board Replacement, LED Board: paso 3, imagen 1 de 2 Google Home LED Board Replacement, LED Board: paso 3, imagen 2 de 2
    • Use a metal spudger to pry the LED board away from the lid.
    • This will require some force because there is a strong adhesive layer that keeps the LED board attached to the lid, so don’t worry about being gentle.
    • Remove the LED board.
Conclusión
Gabe Hyun
Miembro Desde 04/17/18
826 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S24-G11, Maness Spring 2018 Miembro de Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 718
