Saltar al contenido principal
Google Home Interconnect Cable Replacement
Qué necesitas
  1. Google Home Interconnect Cable Replacement, Interconnect Cable: paso 1, imagen 1 de 3 Google Home Interconnect Cable Replacement, Interconnect Cable: paso 1, imagen 2 de 3 Google Home Interconnect Cable Replacement, Interconnect Cable: paso 1, imagen 3 de 3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Interconnect Cable Replacement: paso 2, imagen 1 de 1
    • Carefully remove the interconnect cable using a pair of tweezers.
Conclusión
Gabe Hyun
Miembro Desde 04/17/18
826 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S24-G11, Maness Spring 2018 Miembro de Cal Poly, Team S24-G11, Maness Spring 2018
CPSU-MANESS-S18S24G11
4 Miembros
5 Guías creadas
Un comentario
What cord can you replace with? There is an adaptor attached.
Katti Sundelin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 677
