Saltar al contenido principal
Google Cr-48 Chromebook RAM Replacement
Qué necesitas
  1. Google Cr-48 Chromebook RAM Replacement, Battery: paso 1, imagen 1 de 3 Google Cr-48 Chromebook RAM Replacement, Battery: paso 1, imagen 2 de 3 Google Cr-48 Chromebook RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Google Cr-48 Chromebook RAM Replacement, Remove Rear Rubber Feet: paso 2, imagen 1 de 2 Google Cr-48 Chromebook RAM Replacement, Remove Rear Rubber Feet: paso 2, imagen 2 de 2
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Google Cr-48 Chromebook RAM Replacement, Remove Screws: paso 3, imagen 1 de 3 Google Cr-48 Chromebook RAM Replacement, Remove Screws: paso 3, imagen 2 de 3 Google Cr-48 Chromebook RAM Replacement, Remove Screws: paso 3, imagen 3 de 3
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Google Cr-48 Chromebook RAM Replacement: paso 4, imagen 1 de 3 Google Cr-48 Chromebook RAM Replacement: paso 4, imagen 2 de 3 Google Cr-48 Chromebook RAM Replacement: paso 4, imagen 3 de 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Google Cr-48 Chromebook RAM Replacement, RAM: paso 5, imagen 1 de 3 Google Cr-48 Chromebook RAM Replacement, RAM: paso 5, imagen 2 de 3 Google Cr-48 Chromebook RAM Replacement, RAM: paso 5, imagen 3 de 3
    • Locate the RAM under a black flap alongside where the laptop screen and device body meet.
  6. Google Cr-48 Chromebook RAM Replacement: paso 6, imagen 1 de 3 Google Cr-48 Chromebook RAM Replacement: paso 6, imagen 2 de 3 Google Cr-48 Chromebook RAM Replacement: paso 6, imagen 3 de 3
    • Using your thumbs, pull the metal arms away from the RAM and then the RAM card should pop up.
  7. Google Cr-48 Chromebook RAM Replacement: paso 7, imagen 1 de 2 Google Cr-48 Chromebook RAM Replacement: paso 7, imagen 2 de 2
    • Use two fingers to slide the RAM out at the angle that it has been released.
    • Be careful when removing or replacing the RAM sticks that you don't bend the pins or they won't attach properly to the socket.
Conclusión
2 personas más completaron esta guía.
Athar
Miembro Desde 09/09/14
365 Reputación
2 Guías creadas
Equipo
CSU Fullerton, Team 2-2, Bruce Fall 2014 Miembro de CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 1,944
