Saltar al contenido principal
Google Chromebook Pixel 2 Fan Replacement
Qué necesitas
  1. Google Chromebook Pixel 2 Fan Replacement, Back Panel: paso 1, imagen 1 de 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Fan Replacement: paso 2, imagen 1 de 1
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Fan Replacement: paso 3, imagen 1 de 2 Google Chromebook Pixel 2 Fan Replacement: paso 3, imagen 2 de 2
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Fan Replacement: paso 4, imagen 1 de 1
    • Carefully lift the back panel off of the device.
  5. Google Chromebook Pixel 2 Fan Replacement, Fan: paso 5, imagen 1 de 2 Google Chromebook Pixel 2 Fan Replacement, Fan: paso 5, imagen 2 de 2
    • Remove the three blue 4.0 mm Phillips #00 screws from the fan on the right side.
  6. Google Chromebook Pixel 2 Fan Replacement: paso 6, imagen 1 de 1
    • Using the plastic opening tool, slide out the right fan’s connector out of the motherboard slot.
  7. Google Chromebook Pixel 2 Fan Replacement: paso 7, imagen 1 de 1
    • Carefully remove lift the right fan out of its slot.
  8. Google Chromebook Pixel 2 Fan Replacement: paso 8, imagen 1 de 2 Google Chromebook Pixel 2 Fan Replacement: paso 8, imagen 2 de 2
    • Remove three blue 4.0 mm Phillips #00 screws from the left fan.
  9. Google Chromebook Pixel 2 Fan Replacement: paso 9, imagen 1 de 1
    • Using the plastic opening tool, slide out the left fan’s connector.
  10. Google Chromebook Pixel 2 Fan Replacement: paso 10, imagen 1 de 1
    • Gently lift the left fan out of its slot.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S22-G6, Livingston Spring 2017 Miembro de Cal Poly, Team S22-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G6
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 141
