Saltar al contenido principal
Golf Club Shaft Replacement
Qué necesitas
  1. Golf Club Shaft Replacement, Shaft: paso 1, imagen 1 de 1
    • Use a heat gun to melt the old epoxy holding the club head to the old shaft.
    • Caution: Heat guns can get very hot, so use caution when handling them.
  2. Golf Club Shaft Replacement: paso 2, imagen 1 de 3 Golf Club Shaft Replacement: paso 2, imagen 2 de 3 Golf Club Shaft Replacement: paso 2, imagen 3 de 3
    • Stabilize the club shaft using a vise grip or the weight of a friend.
    • With a pair of oven mitts, remove the club head by carefully twisting it from the shaft.
  3. Golf Club Shaft Replacement: paso 3, imagen 1 de 2 Golf Club Shaft Replacement: paso 3, imagen 2 de 2
    • Clean out the inside of the club head with acetone and a small wire brush.
    • Cleaning the club head will make applying the new epoxy effective.
  4. Golf Club Shaft Replacement: paso 4, imagen 1 de 1
    • Place the cleaned club head on the new shaft and mark the where the end of the club head reaches on the shaft.
    • Remove the club head.
  5. Golf Club Shaft Replacement: paso 5, imagen 1 de 3 Golf Club Shaft Replacement: paso 5, imagen 2 de 3 Golf Club Shaft Replacement: paso 5, imagen 3 de 3
    • Take some sand paper and sand the shaft past your mark leading to the tip.
    • A good technique is to wrap the sandpaper around the tip while twisting the hand holding the sandpaper back and forth.
  6. Golf Club Shaft Replacement: paso 6, imagen 1 de 3 Golf Club Shaft Replacement: paso 6, imagen 2 de 3 Golf Club Shaft Replacement: paso 6, imagen 3 de 3
    • Get the epoxy ready by pouring it into a plate.
    • Use a toothpick to apply epoxy into the part of the club head that goes over the shaft.
  7. Golf Club Shaft Replacement: paso 7, imagen 1 de 3 Golf Club Shaft Replacement: paso 7, imagen 2 de 3 Golf Club Shaft Replacement: paso 7, imagen 3 de 3
    • Slide the new shaft into the club head.
    • Wipe off the excess epoxy that squeezes out.
    • Let the epoxy set overnight for an optimal seal, then it will be ready for use.
Linea de Meta
Una persona más ha completado esta guía.
George Bassili
Miembro Desde 04/30/21
166 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 80
Todo El Tiempo: 1,232
