Saltar al contenido principal
Golf Club Grip Replacement
Qué necesitas
  1. Golf Club Grip Replacement, Grip: paso 1, imagen 1 de 2 Golf Club Grip Replacement, Grip: paso 1, imagen 2 de 2
    • Place the golf club securely on a level table.
    • Using a blade or knife, cut a line through the grip.
  2. Golf Club Grip Replacement: paso 2, imagen 1 de 3 Golf Club Grip Replacement: paso 2, imagen 2 de 3 Golf Club Grip Replacement: paso 2, imagen 3 de 3
    • Remove the grip from the golf club shaft.
  3. Golf Club Grip Replacement: paso 3, imagen 1 de 1
    • Use the knife to take off any excess residue from the shaft of the club.
  4. Golf Club Grip Replacement: paso 4, imagen 1 de 2 Golf Club Grip Replacement: paso 4, imagen 2 de 2
    • Apply the double sided tape to the bare shaft in a spiral pattern.
    • Use the grip to determine how far up the shaft the tape needs to go.
  5. Golf Club Grip Replacement: paso 5, imagen 1 de 1
    • Remove the tape backing.
  6. Golf Club Grip Replacement: paso 6, imagen 1 de 3 Golf Club Grip Replacement: paso 6, imagen 2 de 3 Golf Club Grip Replacement: paso 6, imagen 3 de 3
    • Place a golf tee in the hole at the end of the golf grip.
  7. Golf Club Grip Replacement: paso 7, imagen 1 de 2 Golf Club Grip Replacement: paso 7, imagen 2 de 2
    • Pour a generous amount of adhesive into the opposite end of the grip.
    • Squeeze together the open end of the grip.
    • Lightly shake, in order to spread the adhesive within the grip.
  8. Golf Club Grip Replacement: paso 8, imagen 1 de 1
    • Over a bowl or container, pour adhesive in the grip onto the shaft of the golf club.
  9. Golf Club Grip Replacement: paso 9, imagen 1 de 2 Golf Club Grip Replacement: paso 9, imagen 2 de 2
    • Remove the tee from the back of the grip.
    • Push the grip onto the golf club shaft.
    • Ensure that the end of the grip is hitting the end of the shaft.
  10. Golf Club Grip Replacement: paso 10, imagen 1 de 1
    • Allow to dry at least 12 hours before use.
Conclusión
After allowing the club to properly dry, you will have a new grip to improve your swing at tee off.
6 personas más completaron esta guía.
Skylar Nichols
Miembro Desde 09/30/16
212 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 49
Todo El Tiempo: 6,657
