Saltar al contenido principal
GoPro Karma Stabilizer Replacement
  1. GoPro Karma Stabilizer Replacement, Stabilizer: paso 1, imagen 1 de 3 GoPro Karma Stabilizer Replacement, Stabilizer: paso 1, imagen 2 de 3 GoPro Karma Stabilizer Replacement, Stabilizer: paso 1, imagen 3 de 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  2. GoPro Karma Stabilizer Replacement: paso 2, imagen 1 de 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S25-G14, Maness Spring 2018 Miembro de Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Miembros
6 Guías creadas
Un comentario
My karma got accident and broke two arms on right side. But I tried to start it again and not working anymore.
Friday Aringo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 1,877
