Saltar al contenido principal
GoPro Karma Propeller Replacement
  1. GoPro Karma Propeller Replacement, Battery: paso 1, imagen 1 de 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Propeller Replacement, Stabilizer: paso 2, imagen 1 de 3 GoPro Karma Propeller Replacement, Stabilizer: paso 2, imagen 2 de 3 GoPro Karma Propeller Replacement, Stabilizer: paso 2, imagen 3 de 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Propeller Replacement: paso 3, imagen 1 de 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Propeller Replacement, Propeller: paso 4, imagen 1 de 3 GoPro Karma Propeller Replacement, Propeller: paso 4, imagen 2 de 3 GoPro Karma Propeller Replacement, Propeller: paso 4, imagen 3 de 3
    • Extend the arms and set the drone face up.
    • The front right and back left propellers unscrew clockwise.
    • The front left and back right propellers unscrew counterclockwise.
  5. GoPro Karma Propeller Replacement: paso 5, imagen 1 de 2 GoPro Karma Propeller Replacement: paso 5, imagen 2 de 2
    • Place the GoPro Karma wrench on the motor.
    • Hold the motor in place with the wrench and unscrew the propeller in the indicated direction.
Conclusión
Jay Ingram
Miembro Desde 04/19/18
334 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S25-G14, Maness Spring 2018 Miembro de Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Miembros
6 Guías creadas
2 comentarios
You got it the wrong way around, to take them off you need to do the exact opposite to what you say.
michael.woelk - Contestar
hi, i am trying to fix my Karma. I have to remove the propellers but it is like they are stocked.
I try to unscrew the propellers but i can’t remove them.
Do you know what to do in this case?
Davide Negro - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 1,576
