Saltar al contenido principal
GoPro Karma Landing Gear Replacement
Qué necesitas
  1. GoPro Karma Landing Gear Replacement, Battery: paso 1, imagen 1 de 1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Landing Gear Replacement, Stabilizer: paso 2, imagen 1 de 3 GoPro Karma Landing Gear Replacement, Stabilizer: paso 2, imagen 2 de 3 GoPro Karma Landing Gear Replacement, Stabilizer: paso 2, imagen 3 de 3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Landing Gear Replacement: paso 3, imagen 1 de 1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Landing Gear Replacement, Landing Gear: paso 4, imagen 1 de 1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Landing Gear Replacement: paso 5, imagen 1 de 1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Landing Gear Replacement: paso 6, imagen 1 de 2 GoPro Karma Landing Gear Replacement: paso 6, imagen 2 de 2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
Conclusión
Jay Ingram
Miembro Desde 04/19/18
334 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S25-G14, Maness Spring 2018 Miembro de Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 584
