Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
GoPro Karma Arms Replacement
Qué necesitas
    1. GoPro Karma Arms Replacement, Battery: paso 1, imagen 1 de 1
      • Hook your fingers on the tab and pull out the battery.
      Pregunta a FixBot
      Agregar Comentario
    1. GoPro Karma Arms Replacement, Stabilizer: paso 2, imagen 1 de 3 GoPro Karma Arms Replacement, Stabilizer: paso 2, imagen 2 de 3 GoPro Karma Arms Replacement, Stabilizer: paso 2, imagen 3 de 3
      • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
      • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
      Pregunta a FixBot
      Agregar Comentario
    2. GoPro Karma Arms Replacement: paso 3, imagen 1 de 1
      • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
      Pregunta a FixBot
      Agregar Comentario
    1. GoPro Karma Arms Replacement, Landing Gear: paso 4, imagen 1 de 1
      • Flip the drone upside down with the landing gear out.
      • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
      Pregunta a FixBot
      Agregar Comentario
    2. GoPro Karma Arms Replacement: paso 5, imagen 1 de 1
      • Push with your thumb and pull up with your fingers to remove the landing gear.
      • Caution: The landing gear is connected by a thin cable so do not pull too far away.
      Pregunta a FixBot
      Agregar Comentario
    3. GoPro Karma Arms Replacement: paso 6, imagen 1 de 2 GoPro Karma Arms Replacement: paso 6, imagen 2 de 2
      • Flip over the landing gear and locate the cable connector.
      • Use your thumbnail to disconnect the cable and free the landing gear.
      Pregunta a FixBot
      Agregar Comentario
    1. GoPro Karma Arms Replacement, Arms: paso 7, imagen 1 de 1
      • Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
      Pregunta a FixBot
      Agregar Comentario
    2. GoPro Karma Arms Replacement: paso 8, imagen 1 de 2 GoPro Karma Arms Replacement: paso 8, imagen 2 de 2
      • Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
      • The connector release tool is only included with the purchase of a replacement arm from the GoPro website.
      • If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
      Pregunta a FixBot
      Agregar Comentario
    3. GoPro Karma Arms Replacement: paso 9, imagen 1 de 3 GoPro Karma Arms Replacement: paso 9, imagen 2 de 3 GoPro Karma Arms Replacement: paso 9, imagen 3 de 3
      • Remove the cover plate by pulling up on the side.
      • Feed each connector through the hole and set aside the cover plate.
      Pregunta a FixBot
      Agregar Comentario
    4. GoPro Karma Arms Replacement: paso 10, imagen 1 de 2 GoPro Karma Arms Replacement: paso 10, imagen 2 de 2
      • Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
      • The screw will not come out but loosen it until it can rotate easily.
      • Pull up and off the broken arm.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Kyle Hoff
Miembro Desde 04/23/18
141 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S25-G14, Maness Spring 2018 Miembro de Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
Miembros de 4
72 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 27
Todo El Tiempo: 2,713
