Introducción
Replacing an arm on the Karma can be done in less than 20 minutes. There are four main steps: removing the landing gear, removing the old arm, installing the new arm, reattaching the landing gear. This video will walk you through each step.
Herramientas
Partes
Instrucciones de Vídeo
3 personas más completaron esta guía.
3 comentarios
Juste merci !
cedricgaeta - Contestar
Can someone tell me what tools are needed? I’m looking first to see if I can repait a slightly cracked arm before needing to replace?
lenodski - Contestar
The only tool needed is a 2.5mm hex key.
Blake Klein -
