Saltar al contenido principal
GoPro Hero5 Black Lens Assembly Replacement
Qué necesitas
  1. GoPro Hero5 Black Lens Assembly Replacement, Battery: paso 1, imagen 1 de 3 GoPro Hero5 Black Lens Assembly Replacement, Battery: paso 1, imagen 2 de 3 GoPro Hero5 Black Lens Assembly Replacement, Battery: paso 1, imagen 3 de 3
    • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
  2. GoPro Hero5 Black Lens Assembly Replacement: paso 2, imagen 1 de 3 GoPro Hero5 Black Lens Assembly Replacement: paso 2, imagen 2 de 3 GoPro Hero5 Black Lens Assembly Replacement: paso 2, imagen 3 de 3
    • Grab the plastic flap on the battery and pull the battery out.
  3. GoPro Hero5 Black Lens Assembly Replacement, Back Housing: paso 3, imagen 1 de 2 GoPro Hero5 Black Lens Assembly Replacement, Back Housing: paso 3, imagen 2 de 2
    • Pull and twist the lens cover right or left until it pops off.
    • The lens cover is secured tightly and might be difficult to twist off.
  4. GoPro Hero5 Black Lens Assembly Replacement: paso 4, imagen 1 de 1
    • This step is not necessary but will make the process of removing the faceplate much easier.
    • Refer to the iOpener instructions for how to heat up and use the iOpener.
    • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
    • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
  5. GoPro Hero5 Black Lens Assembly Replacement: paso 5, imagen 1 de 3 GoPro Hero5 Black Lens Assembly Replacement: paso 5, imagen 2 de 3 GoPro Hero5 Black Lens Assembly Replacement: paso 5, imagen 3 de 3
    • Starting with the edges, use the spudger to pry off the faceplate.
    • The faceplate is held down with adhesive and may take a while to get off.
  6. GoPro Hero5 Black Lens Assembly Replacement: paso 6, imagen 1 de 2 GoPro Hero5 Black Lens Assembly Replacement: paso 6, imagen 2 de 2
    • Remove the six T3 Torx screws.
  7. GoPro Hero5 Black Lens Assembly Replacement: paso 7, imagen 1 de 3 GoPro Hero5 Black Lens Assembly Replacement: paso 7, imagen 2 de 3 GoPro Hero5 Black Lens Assembly Replacement: paso 7, imagen 3 de 3
    • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
    • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
  8. GoPro Hero5 Black Lens Assembly Replacement: paso 8, imagen 1 de 3 GoPro Hero5 Black Lens Assembly Replacement: paso 8, imagen 2 de 3 GoPro Hero5 Black Lens Assembly Replacement: paso 8, imagen 3 de 3
    • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
  9. GoPro Hero5 Black Lens Assembly Replacement: paso 9, imagen 1 de 2 GoPro Hero5 Black Lens Assembly Replacement: paso 9, imagen 2 de 2
    • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
  10. GoPro Hero5 Black Lens Assembly Replacement, Motherboard: paso 10, imagen 1 de 1
    • Use the flat end of the spudger to pry the black cover plate straight up from its socket on the motherboard.
  11. GoPro Hero5 Black Lens Assembly Replacement: paso 11, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to pull the ribbon cable connector out of its white socket on the charging assembly board.
  12. GoPro Hero5 Black Lens Assembly Replacement: paso 12, imagen 1 de 2 GoPro Hero5 Black Lens Assembly Replacement: paso 12, imagen 2 de 2
    • Remove the two #000 Phillips screw.
  13. GoPro Hero5 Black Lens Assembly Replacement: paso 13, imagen 1 de 2 GoPro Hero5 Black Lens Assembly Replacement: paso 13, imagen 2 de 2
    • Use the flat end of the spudger to pry the charging port ribbon cable connector straight up from its socket on the motherboard.
    • Once the ribbon cable is disconnected from the motherboard. The charging port assembly should come right off.
  14. GoPro Hero5 Black Lens Assembly Replacement: paso 14, imagen 1 de 2 GoPro Hero5 Black Lens Assembly Replacement: paso 14, imagen 2 de 2
    • Remove the 10mm #000 Phillips screw.
  15. GoPro Hero5 Black Lens Assembly Replacement: paso 15, imagen 1 de 1
    • Remove the charging assembly housing by pulling it straight up off the motherboard.
  16. GoPro Hero5 Black Lens Assembly Replacement: paso 16, imagen 1 de 2 GoPro Hero5 Black Lens Assembly Replacement: paso 16, imagen 2 de 2
    • Remove the two 6mm #000 Phillips screws.
    • Remove the two 2mm #000 Phillips screws.
  17. GoPro Hero5 Black Lens Assembly Replacement: paso 17, imagen 1 de 1
    • Use the flat end of the spudger to pry the lens assembly ribbon cable connector straight up from its socket on the motherboard.
  18. GoPro Hero5 Black Lens Assembly Replacement: paso 18, imagen 1 de 1
    • Use the flat end of the spudger to pry the LCD screen ribbon cable connector straight up from its socket on the motherboard.
  19. GoPro Hero5 Black Lens Assembly Replacement: paso 19, imagen 1 de 3 GoPro Hero5 Black Lens Assembly Replacement: paso 19, imagen 2 de 3 GoPro Hero5 Black Lens Assembly Replacement: paso 19, imagen 3 de 3
    • Use the flat end of the spudger to pry the motherboard off the midframe.
    • The motherboard is held onto the midframe with light adhesive and should come right off with a little force.
  20. GoPro Hero5 Black Lens Assembly Replacement, Lens Assembly: paso 20, imagen 1 de 2 GoPro Hero5 Black Lens Assembly Replacement, Lens Assembly: paso 20, imagen 2 de 2
    • Remove the 2mm #000 Phillips screws using a #000 Phillips head screwdriver or tool bit.
  21. GoPro Hero5 Black Lens Assembly Replacement: paso 21, imagen 1 de 2 GoPro Hero5 Black Lens Assembly Replacement: paso 21, imagen 2 de 2
    • Pull the lens assembly straight out from the Midframe.
Conclusión
16 personas más completaron esta guía.
Equipo
Cal Poly, Team 18-6, Forte Fall 2016 Miembro de Cal Poly, Team 18-6, Forte Fall 2016
CPSU-FORTE-F16S18G6
4 Miembros
22 Guías creadas
7 comentarios
RageCams has interchangeable lens mod for hero5
http://ragecams.com/shop/modified-gopro-...
dennis - Contestar
why can't You show how the lens is mount to that assembly? That's the point of it... can we change lenses that way or not?
Polina Luzenco - Contestar
Exactly. Can the actual lens be unscrewed from the mount or it glued / fixed?
contact -
The lens is heavily glued onto the assembly. It would be far easier to replace the entire assembly than trying to remove that glue.
Christopher Adams -
the guy who wrote the guide apparently has never heard of pliers. it comes right out, but no idea what the threading is.
mattatron4 -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 49
Todo El Tiempo: 16,086
