Saltar al contenido principal
GoPro Hero4 Black LCD Screen Replacement
Qué necesitas
  1. GoPro Hero4 Black LCD Screen Replacement, Midframe Housing: paso 1, imagen 1 de 3 GoPro Hero4 Black LCD Screen Replacement, Midframe Housing: paso 1, imagen 2 de 3 GoPro Hero4 Black LCD Screen Replacement, Midframe Housing: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. GoPro Hero4 Black LCD Screen Replacement: paso 2, imagen 1 de 2 GoPro Hero4 Black LCD Screen Replacement: paso 2, imagen 2 de 2
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. GoPro Hero4 Black LCD Screen Replacement: paso 3, imagen 1 de 2 GoPro Hero4 Black LCD Screen Replacement: paso 3, imagen 2 de 2
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. GoPro Hero4 Black LCD Screen Replacement: paso 4, imagen 1 de 3 GoPro Hero4 Black LCD Screen Replacement: paso 4, imagen 2 de 3 GoPro Hero4 Black LCD Screen Replacement: paso 4, imagen 3 de 3
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
  5. GoPro Hero4 Black LCD Screen Replacement, LCD Screen: paso 5, imagen 1 de 2 GoPro Hero4 Black LCD Screen Replacement, LCD Screen: paso 5, imagen 2 de 2
    • Open the clip that is located on the motherboard
    • Use a pair of tweezers to pull the ribbon from the clip
  6. GoPro Hero4 Black LCD Screen Replacement: paso 6, imagen 1 de 3 GoPro Hero4 Black LCD Screen Replacement: paso 6, imagen 2 de 3 GoPro Hero4 Black LCD Screen Replacement: paso 6, imagen 3 de 3
    • Before you start this step flip the section holding the LCD screen over
    • Place the iOpener on the LCD screen cover to release the glue
    • Lift the covering of the LCD screen cover off with a pair of tweezers
  7. GoPro Hero4 Black LCD Screen Replacement: paso 7, imagen 1 de 2 GoPro Hero4 Black LCD Screen Replacement: paso 7, imagen 2 de 2
    • Use a pair of tweezers to lift the ribbon through the opening and lift all the way up to the LCD screen
    • A section of our LCD screen ribbon was broken so it is not visible from the image.
  8. GoPro Hero4 Black LCD Screen Replacement: paso 8, imagen 1 de 2 GoPro Hero4 Black LCD Screen Replacement: paso 8, imagen 2 de 2
    • Place the iOpener on the LCD screen to remove the glue
    • Use a pair of tweezers to left the LCD screen off the device
Conclusión
5 personas más completaron esta guía.
Jeffrey Goethe
Miembro Desde 02/20/17
674 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S2-G1, Sullivan Spring 2017 Miembro de USF Tampa, Team S2-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G1
Miembros de 4
12 Guías creadas
4Guía Comentarios
Bonjour , est ce que je peux installer un écran LCD sur une hero 4 silver ( sans écran LCD d'origine ) . Je dispose d'une hero 4 black LCD HS . Merci de vos réponses. Sébastien
Coolsaet - Contestar
No, ce n'est malheureusement pas possible.
Der Zurechtweiser -
You got the screw locations on the front wrong. Bottom left is the shortest screw, where the battery compartment is. If you try putting one of the longer screws through their it'll bust into the battery compartment. Ask me how I know. And that's the one reason why I came to this, the one thing I couldn't remember.
fat_toni987 - Contestar
My GoPro Hero4 Black Button Won't Click After Screen Replacement
I did the GoPro Hero4 Black LCD Screen Replacement. The problem is, I don't get the button to click with the Midframe Housing on. Pressing the naked button works, but the mode plastic button doesn't work when placed above it, there is no clicking sound and no function.
Should I put a placeholder somewhere?
What could be the solution?
Der Zurechtweiser - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 41
Todo El Tiempo: 8,265
