Introducción
This guide will show how to replace the camera sensor. The camera sensor collects light to create the image. If your pictures are blurry or low on brightness, the camera sensor may need a replacement.
Qué necesitas
Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
Use the tweezers to lift the faceplate from the rest of the device.
Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
7 personas más completaron esta guía.
2 comentarios
not easy to return the ribbon back to its place! it’s easier to throw your gopro after doing this.
Hi, is the sensor for black and silver same? Thank you
