Saltar al contenido principal
GoPro Hero3+ Silver Edition Camera Lens Replacement
Qué necesitas
  1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: paso 1, imagen 1 de 2 GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: paso 1, imagen 2 de 2
    • Push the tab on the back of the device left to remove the plate covering the battery.
  2. GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 2, imagen 1 de 1
    • Use the strip of tape on the battery to remove the battery from the housing.
  3. GoPro Hero3+ Silver Edition Camera Lens Replacement, Front Panel: paso 3, imagen 1 de 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  4. GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 4, imagen 1 de 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
  5. GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: paso 5, imagen 1 de 3 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: paso 5, imagen 2 de 3 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: paso 5, imagen 3 de 3
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
  6. GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 6, imagen 1 de 2 GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 6, imagen 2 de 2
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
  7. GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 7, imagen 1 de 1
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
  8. GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 8, imagen 1 de 2 GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 8, imagen 2 de 2
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
  9. GoPro Hero3+ Silver Edition Camera Lens Replacement, microSD/Expansion Port Assembly: paso 9, imagen 1 de 1
    • Using your screwdriver, unscrew three 4mm PH00 screws that will free the metal plate.
    • A small plate will become separated when the rightmost screw is removed. Just place it to the side.
  10. GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 10, imagen 1 de 2 GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 10, imagen 2 de 2
    • Use the plastic opening tool to pry off the referenced ribbon cable from the motherboard.
    • The microSD and Accessory Board is now ready for removal.
  11. GoPro Hero3+ Silver Edition Camera Lens Replacement, Motherboard: paso 11, imagen 1 de 1
    • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
  12. GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 12, imagen 1 de 3 GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 12, imagen 2 de 3 GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 12, imagen 3 de 3
    • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
    • Gently remove the motherboard from the midframe using tweezers.
    • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
  13. GoPro Hero3+ Silver Edition Camera Lens Replacement, Camera Lens: paso 13, imagen 1 de 1
    • Use your PH00 screwdriver to remove the last three screws from the mid frame. This will release the lens housing from the mid frame.
  14. GoPro Hero3+ Silver Edition Camera Lens Replacement: paso 14, imagen 1 de 1
    • Carefully remove the lens from the font housing.
Conclusión
9 personas más completaron esta guía.
Patrick Cook
Miembro Desde 10/01/15
687 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-8, Maness Fall 2015 Miembro de Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 2,129
