Saltar al contenido principal
GoPro Hero Lens Replacement
Qué necesitas
  1. GoPro Hero Lens Replacement, Casing: paso 1, imagen 1 de 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Lens Replacement: paso 2, imagen 1 de 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Lens Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Lens Replacement: paso 4, imagen 1 de 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Lens Replacement: paso 5, imagen 1 de 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Lens Replacement: paso 6, imagen 1 de 1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Lens Replacement, Lens: paso 7, imagen 1 de 1
    • Remove the four screws from the lens.
    • These screws are smaller than the ones removed from the white plastic piece.
  8. GoPro Hero Lens Replacement: paso 8, imagen 1 de 1
    • Remove the lens from the case.
Conclusión
To reassemble your device, follow the instructions in reverse order.
3 personas más completaron esta guía.
River Drake
Miembro Desde 04/02/15
1,035 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-2, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Miembros
18 Guías creadas
Un comentario
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
Doggo Boi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 63
Todo El Tiempo: 12,638
