Saltar al contenido principal
Introducción
In order to replace or fix components in this camera, it is necessary to take of the back and get to the "guts" of the camera. This is because the camera does not come out of the case.
  1. Power off your GoPro before beginning disassembly.
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. Gently pry the back open by inserting a metal spudger between the case and back panel.
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. Carefully remove the motherboard and white plastic piece from the case.
    • Carefully remove the motherboard and white plastic piece from the case.
Conclusión
River Drake
Miembro Desde 02/04/15
1,005 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-2, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 113
