Introducción
A rhinoceros ate the rear case of your GoPro? No questions here; you can replace it with a new one.
  1. Place your thumb on the indentation in the back case on the side of the GoPro. Gently press down with your thumb and lift the back cover away from the case to remove it.
    • Place your thumb on the indentation in the back case on the side of the GoPro.
    • Gently press down with your thumb and lift the back cover away from the case to remove it.
  2. Slide a plastic opening tool between the battery and the rear case. Gently pry the battery up and out of the rear case.
    • Slide a plastic opening tool between the battery and the rear case.
    • Gently pry the battery up and out of the rear case.
  3. Remove the battery from the case.
    • Remove the battery from the case.
  4. Remove the four Phillips #00 screws securing the rear case to the rest of the device:
    • Remove the four Phillips #00 screws securing the rear case to the rest of the device:
      • Two 5.5 mm coarse thread screws.
      • Two 4.4 mm fine thread screws.
  5. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    Todos somos Genios
  6. Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up. Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
    • Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up.
    • Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
  7. Grasp the rear case and lift it off of the front case. Do not try to completely remove the rear case yet, as it is still attached by the display port ribbon cable.
    • Grasp the rear case and lift it off of the front case.
    • Do not try to completely remove the rear case yet, as it is still attached by the display port ribbon cable.
  8. Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly. Be careful that you are prying on the locking tab, and not the connector itself.
    • Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
      • Be careful that you are prying on the locking tab, and not the connector itself.
    • Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
  9. Lift the speaker out of the rear case with the tip of a spudger. Remove the rear case. Remove the rear case.
    • Lift the speaker out of the rear case with the tip of a spudger.
    • Remove the rear case.
  10. Remove the two 5.8 mm Phillips #00 screws securing the SD board cover to the rear case.
    • Remove the two 5.8 mm Phillips #00 screws securing the SD board cover to the rear case.
  11. Turn the rear case over so that the SD card slot is facing you. Use the tip of a spudger to push the bottom of the SD board cover up and out of the rear case. Turn the rear case back over.
    • Turn the rear case over so that the SD card slot is facing you.
    • Use the tip of a spudger to push the bottom of the SD board cover up and out of the rear case.
    • Turn the rear case back over.
    • Lift the SD board cover out of the rear case with the tip of a spudger and remove it.
  12. Grasp the SD board ribbon cable gently and pull the SD board out of the rear case. Grasp the SD board ribbon cable gently and pull the SD board out of the rear case.
    • Grasp the SD board ribbon cable gently and pull the SD board out of the rear case.
  13. The rear case remains.
    • The rear case remains.
Conclusión
David Hodson
Miembro Desde 13/04/10
133,491 Reputación
127 Guías creadas
FYI the item that you're disassembling is not the SD card slot, it's the plug for HD Hero accessories such as the Wifi backpack and LCD screen. The SD card is inserted from the side not the back.
Mike Keane - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 2,566
