Saltar al contenido principal
Globe Light Bulb Replacement
  1. Globe Light Bulb Replacement, light bulb: paso 1, imagen 1 de 2 Globe Light Bulb Replacement, light bulb: paso 1, imagen 2 de 2
    • With a plastic meridian like this one, you need to raise the meridian slightly from the North Pole. Use the plastic ring on the north pole to gently press the globe down and pull up the meridian so you lift the little pin,which holdes the globe.
  2. Globe Light Bulb Replacement: paso 2, imagen 1 de 1
    • Now you can slowly turn the globe to the side and lift it from the socket at the south pole.
    • Be careful not to scratch the globe with the meridian.
  3. Globe Light Bulb Replacement: paso 3, imagen 1 de 1
    • You can replace the bulb now. Screw the new bulb into the socket.
    • Please make sure that you are using an equivalent bulb.
  4. Globe Light Bulb Replacement: paso 4, imagen 1 de 1
    • Finally install the globe again by placing it back on the south pole and fixing the meridian on to the north pole.
  5. Globe Light Bulb Replacement: paso 5, imagen 1 de 1
    • Your globe is now glowing bright again.
Linea de Meta
Una persona más ha completado esta guía.
Athina Pilitsidou
Miembro Desde 07/19/18
171 Reputación
1 Guía escrita
Equipo
iFixit Miembro de iFixit
Community
136 Miembros
15,176 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 19
Ultimos 30 días: 108
Todo El Tiempo: 5,885
