Saltar al contenido principal
Introducción
There are many benefits to repairing your own watch such as cheaper than replacing the whole watch or taking it to a jeweler, and maintaining the sentimental value when repairing it yourself. No prior technical experience is required, just a little patience and literacy!
  1. Place the watch in the band holder.
    • Place the watch in the band holder.
    • Make sure to align the band pin directly over one of the holes.
  2. Use your pin push and rubber mallet to knock it through.
    • Use your pin push and rubber mallet to knock it through.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Use your pliers to pull the pin the rest of the way through.
    • Use your pliers to pull the pin the rest of the way through.
  5. Repeat steps 1-3 on the other side to fully release the old clasp from the watch. Repeat steps 1-3 on the other side to fully release the old clasp from the watch. Repeat steps 1-3 on the other side to fully release the old clasp from the watch.
    • Repeat steps 1-3 on the other side to fully release the old clasp from the watch.
  6. Slide the pin back in halfway, then reattach both sides of your new clasp to your watch.
    • Slide the pin back in halfway, then reattach both sides of your new clasp to your watch.
Conclusión
Caleb Shuford
Miembro Desde 22/02/18
121 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 19
Todo El Tiempo: 220
