Introducción
Installing a tube.
Qué necesitas
Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
Push the axle screw to reveal the axle rod on the other side.
Look at your tire and determine the correct tube size by locating the number (formated ## x #.##) on the wall of the tire.
Una persona más ha completado esta guía.
