Saltar al contenido principal
Giant Reign 2 Rear Shock Replacement
Qué necesitas
  1. Giant Reign 2 Rear Shock Replacement, Rear Shock: paso 1, imagen 1 de 1
    • Orient the bike upside down.
  2. Giant Reign 2 Rear Shock Replacement: paso 2, imagen 1 de 1
    • Remove the 10mm screw and take the bash guard off of the frame.
  3. Giant Reign 2 Rear Shock Replacement: paso 3, imagen 1 de 1
    • Remove the 65mm screw that connects the bottom of the shock to the frame.
    • Use a wrench to hold the other side.
  4. Giant Reign 2 Rear Shock Replacement: paso 4, imagen 1 de 1
    • Remove the 40mm screw that connects the shock to the link arm of the suspension.
  5. Giant Reign 2 Rear Shock Replacement: paso 5, imagen 1 de 2 Giant Reign 2 Rear Shock Replacement: paso 5, imagen 2 de 2
    • Push the shock out of the brackets mounting it to the frame and suspension arm.
    • This may require some force and slight wiggling from side to side.
Conclusión
Una persona más ha completado esta guía.
Andrew Krasts
Miembro Desde 10/05/12
302 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-14, Amido Fall 2012 Miembro de Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Miembros
10 Guías creadas
Un comentario
Which valve stem is the one to put air into the shock there's one on the bottom one on top and adjustment knob right next to the top one
Ron Hobson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 28
Todo El Tiempo: 4,933
