Saltar al contenido principal
Getting randomly stuck at 100% input
Qué necesitas
  1. Getting randomly stuck at 100% input, Perform Maintenance: paso 1, imagen 1 de 1
    • You can find a guide on how to perform that here.
  2. Getting randomly stuck at 100% input, Remove your carpet: paso 2, imagen 1 de 1
    • If you have a carpet underneath your setup, remove it.
    • If the carpet is built into the floor, buy an anti-static floor mat to fit underneath your setup.
    • Create a path from your rig or pedals to Earth, so that static electricity would dissipate through it.
    • Not all homes have grounding built-in. You may need to get creative or create grounding yourself.
    • Understanding the ESD is important. Read more about it here, here and here.
Conclusión
Eliminating possibility of Electro-Static Discharge will prevent your pedal getting randomly stuck at 100% or 50% input.
Formica Fusca
Miembro Desde 08/01/24
2,587 Reputación
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 68
