Saltar al contenido principal
Genesis II CSS-315 Ignitor Replacement
Qué necesitas
  1. Genesis II CSS-315 Ignitor Replacement, Ignitor: paso 1, imagen 1 de 2 Genesis II CSS-315 Ignitor Replacement, Ignitor: paso 1, imagen 2 de 2
    • Be sure the grill is turned off before beginning this guide.
    • Remove all of the control knobs.
    • The amount of knobs may vary depending on the grill.
  2. Genesis II CSS-315 Ignitor Replacement: paso 2, imagen 1 de 2 Genesis II CSS-315 Ignitor Replacement: paso 2, imagen 2 de 2
    • Remove the two 19 mm screws below the control knob panel using a Phillips #3 screwdriver.
  3. Genesis II CSS-315 Ignitor Replacement: paso 3, imagen 1 de 2 Genesis II CSS-315 Ignitor Replacement: paso 3, imagen 2 de 2
    • Push up on the front panel, and pull it up above the grill.
    • Potential for device damage: The ignitor is connected to the front panel, so do not pull too hard.
  4. Genesis II CSS-315 Ignitor Replacement: paso 4, imagen 1 de 2 Genesis II CSS-315 Ignitor Replacement: paso 4, imagen 2 de 2
    • Disconnect the cables from the ignitor.
  5. Genesis II CSS-315 Ignitor Replacement: paso 5, imagen 1 de 1
    • Pinch the two ends of the ignitor and remove the ignitor from the front panel.
  6. Genesis II CSS-315 Ignitor Replacement: paso 6, imagen 1 de 1
    • Have the new ignitor on hand, and make sure that the clips on the side are in good condition.
    • Ensure that the pins at the end are straight and not bent.
  7. Genesis II CSS-315 Ignitor Replacement: paso 7, imagen 1 de 3 Genesis II CSS-315 Ignitor Replacement: paso 7, imagen 2 de 3 Genesis II CSS-315 Ignitor Replacement: paso 7, imagen 3 de 3
    • Put the new ignitor into the socket.
    • Press down evenly until it is secure.
  8. Genesis II CSS-315 Ignitor Replacement: paso 8, imagen 1 de 1
    • Connect the white cables to the ignitor.
  9. Genesis II CSS-315 Ignitor Replacement: paso 9, imagen 1 de 2 Genesis II CSS-315 Ignitor Replacement: paso 9, imagen 2 de 2
    • Make sure any and all cables are separated from the fire box (the bottom of the grill).
    • Slot the panel back on the grill and then push downward.
    • The fire box is the part of the grill that gets really hot, and this can damage the cables.
  10. Genesis II CSS-315 Ignitor Replacement: paso 10, imagen 1 de 1
    • Make sure the holes match and reinsert the screws from Step 2 using a Phillips #3 screwdriver.
    • If the holes do not match up, you may have to gently push or pull the front plastic panel.
  11. Genesis II CSS-315 Ignitor Replacement: paso 11, imagen 1 de 2 Genesis II CSS-315 Ignitor Replacement: paso 11, imagen 2 de 2
    • Add the control knobs, and slot them into place.
Linea de Meta
Una persona más ha completado esta guía.
Carlos Castro Paguaga
Miembro Desde 01/18/21
253 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 27
Todo El Tiempo: 564
