Saltar al contenido principal
Generic TV Remote IR LED Replacement
Qué necesitas
  1. Generic TV Remote IR LED Replacement, IR LED: paso 1, imagen 1 de 2 Generic TV Remote IR LED Replacement, IR LED: paso 1, imagen 2 de 2
    • Starting to the side of the front LED, pry up the top of the remote.
    • Remove the top of the remote to expose the circuit board.
  2. Generic TV Remote IR LED Replacement: paso 2, imagen 1 de 3 Generic TV Remote IR LED Replacement: paso 2, imagen 2 de 3 Generic TV Remote IR LED Replacement: paso 2, imagen 3 de 3
    • Remove the circuit board by gently lifting it from the casing.
    • Flip over the board so that the leads of the LED are facing upward.
  3. Generic TV Remote IR LED Replacement: paso 3, imagen 1 de 1
    • Clip the leads of the LED.
    • Bend the LED downward until it makes a 90 degree angle with the circuit board.
  4. Generic TV Remote IR LED Replacement: paso 4, imagen 1 de 1
    • Desolder the broken LED using a soldering iron and desoldering braid.
  5. Generic TV Remote IR LED Replacement: paso 5, imagen 1 de 1
    • Solder the new LED in the same spot as the old one.
    • Make sure that the longer lead (positive) goes through the opening marked positive (+) before soldering.
  6. Generic TV Remote IR LED Replacement: paso 6, imagen 1 de 3 Generic TV Remote IR LED Replacement: paso 6, imagen 2 de 3 Generic TV Remote IR LED Replacement: paso 6, imagen 3 de 3
    • Make sure the buttons and the circuit board are placed correctly before reassembly.
  7. Generic TV Remote IR LED Replacement: paso 7, imagen 1 de 1
    • To check if your remote is now working, first make sure the batteries are in correctly. Then, press any button and aim the remote at a smartphone camera. If the LED is working, a red flashing light will be reflected in the camera.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 111
Todo El Tiempo: 12,788
