Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introducción
Use this guide to replace the cord that connects the handset and the base
Partes
No se especificaron partes.
  1. Unplug the device before proceeding. Using a plastic opening tool, remove the phone cord from the phone jack from the base of the headset.
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack from the base of the headset.
  2. Remove the phone cord screw cap. Unscrew the 7.5mm screw. Remove the screw cap.
    • Remove the phone cord screw cap.
    • Unscrew the 7.5mm screw.
    • Remove the screw cap.
    • Remove the cord from the phone base.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 16-59, Forte Fall 2012 Miembro de Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 826
