Introducción
Use this guide to replace the internal battery of the handset
Qué necesitas
Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
Remove the plastic cover with a plastic opening tool by gently sliding the tool underneath the plastic and pry the cover off.
Use tweezers to apply pressure on battery holder tabs.
Apply pressure directly on battery holder to slide it through the shell.
Battery is going to slide through the bottom.
Una persona más ha completado esta guía.
