Saltar al contenido principal
General Electric Telephone 2-9710A 3V Headset Battery Replacement
Qué necesitas
  1. General Electric Telephone 2-9710A 3V Headset Battery Replacement, Phone Cord: paso 1, imagen 1 de 2 General Electric Telephone 2-9710A 3V Headset Battery Replacement, Phone Cord: paso 1, imagen 2 de 2
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 2, imagen 1 de 3 General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 2, imagen 2 de 3 General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 2, imagen 3 de 3
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. General Electric Telephone 2-9710A 3V Headset Battery Replacement, General Electric Telephone 2-9710A Handset: paso 3, imagen 1 de 2 General Electric Telephone 2-9710A 3V Headset Battery Replacement, General Electric Telephone 2-9710A Handset: paso 3, imagen 2 de 2
    • Remove the plastic cover with a plastic opening tool by gently sliding the tool underneath the plastic and pry the cover off.
  4. General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 4, imagen 1 de 1
    • Remove the paper with a plastic opening tool by gently sliding the tool underneath and prying the paper away from the phone.
  5. General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 5, imagen 1 de 2 General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 5, imagen 2 de 2
    • Remove the rubber stopper with a plastic opening tool by gently sliding the tool underneath and pry away from the phone.
  6. General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 6, imagen 1 de 2 General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 6, imagen 2 de 2
    • Remove the two 2.1 mm screws with a Phillips #1 screwdriver.
  7. General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 7, imagen 1 de 1
    • Pull apart the handset by pulling the top shell away from the other half of the phone.
  8. General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 8, imagen 1 de 2 General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 8, imagen 2 de 2
    • Remove 3 screws attaching the motherboard to shell.
    • Remove the 13 mm screw with a Philips #1 screwdriver.
    • Remove the two 13 mm screws with washers with a Philips #1 screwdriver.
  9. General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 9, imagen 1 de 2 General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 9, imagen 2 de 2
    • Slide the phone jack out from the shell by gently lifting up the female phone jack connector.
  10. General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 10, imagen 1 de 1
    • Without removing the motherboard completely, pull up slightly and pivot the motherboard out of the shell.
    • Be careful not to pull the connectors out.
  11. General Electric Telephone 2-9710A 3V Headset Battery Replacement, 3V Headset Battery: paso 11, imagen 1 de 1
    • Use tweezers to apply pressure on battery holder tabs.
    • Apply pressure directly on battery holder to slide it through the shell.
    • Battery is going to slide through the bottom.
  12. General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 12, imagen 1 de 2 General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 12, imagen 2 de 2
    • Lift tabs on the side of the holder by putting your fingers directly on the tab to pull it apart.
    • While holding the battery, remove it from the holder.
  13. General Electric Telephone 2-9710A 3V Headset Battery Replacement: paso 13, imagen 1 de 1
    • Now insert the new battery.
    • Ensure that the positive side of the battery is facing the tabs.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 16-59, Forte Fall 2012 Miembro de Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,282
