Introducción
If your camera will not power on, one issue could be the power supply button. This guide will demonstrate how to fix this issue.
Qué necesitas
Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
Herramienta utilizada en este paso:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Locate the metal frame removed from around the camera in step 3.
Lay the frame button side down or flat and gently pry the button out of place with the 3.0 flathead bit or a pair of tweezers.
The button is secured to the frame by two small black rods pushed into the white colored portion of the button (see picture).
