Saltar al contenido principal
General Disassembly LG VX8560
Qué necesitas
  1. General Disassembly LG VX8560, General Disassembly LG VX8560: paso 1, imagen 1 de 1
    • Flip phone over so its backside is facing up.
  2. General Disassembly LG VX8560: paso 2, imagen 1 de 1
    • Push from indentation and slide battery cover away from phone to remove battery cover.
  3. General Disassembly LG VX8560: paso 3, imagen 1 de 1
    • Take out the battery once cover is off by gently prying with your fingers.
  4. General Disassembly LG VX8560: paso 4, imagen 1 de 1
    • Using a philips screwdriver, unscrew all 4 screws along the edge of the phone
  5. General Disassembly LG VX8560: paso 5, imagen 1 de 2 General Disassembly LG VX8560: paso 5, imagen 2 de 2
    • Using your plastic pry tool, insert the tool between the phone’s keypad cover and back cover and gently pry apart.
  6. General Disassembly LG VX8560: paso 6, imagen 1 de 1
    • Once the covers have been separated the motherboard will be visible. Do not separate the two covers completely. The covers will be held together by a screw on the axis of the phone.
Conclusión
Una persona más ha completado esta guía.
Jack Foley
Miembro Desde 04/25/13
37 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 13-62, Johann Spring 2013 Miembro de Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
4 Miembros
12 Guías creadas
Un comentario
Concerning a LG Chocolate 3 still activated and perfectly working but with a damaged frame. Can you take the activated internal parts out of a damaged frame phone and install in a like new condition identical phone frame ?
Zamora - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 398
