Saltar al contenido principal
GeeksPhone Keon Screen Replacement
Qué necesitas
  1. GeeksPhone Keon Screen Replacement, Battery: paso 1, imagen 1 de 2 GeeksPhone Keon Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon Screen Replacement: paso 2, imagen 1 de 1
    • Lift the cover away from the phone.
  3. GeeksPhone Keon Screen Replacement: paso 3, imagen 1 de 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
  4. GeeksPhone Keon Screen Replacement, Back Plate: paso 4, imagen 1 de 2 GeeksPhone Keon Screen Replacement, Back Plate: paso 4, imagen 2 de 2
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
  5. GeeksPhone Keon Screen Replacement: paso 5, imagen 1 de 2 GeeksPhone Keon Screen Replacement: paso 5, imagen 2 de 2
    • Gently remove the small orange plate by pulling it down.
  6. GeeksPhone Keon Screen Replacement: paso 6, imagen 1 de 1
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
  7. GeeksPhone Keon Screen Replacement: paso 7, imagen 1 de 3 GeeksPhone Keon Screen Replacement: paso 7, imagen 2 de 3 GeeksPhone Keon Screen Replacement: paso 7, imagen 3 de 3
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
  8. GeeksPhone Keon Screen Replacement: paso 8, imagen 1 de 2 GeeksPhone Keon Screen Replacement: paso 8, imagen 2 de 2
    • Lift the backplate away from the device.
  9. GeeksPhone Keon Screen Replacement, Motherboard: paso 9, imagen 1 de 2 GeeksPhone Keon Screen Replacement, Motherboard: paso 9, imagen 2 de 2
    • Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    • Remove the wire from the bottom left of the motherboard by lifting it away from the device.
    • Remove the 2mm T3 screw in the upper left corner of the motherboard.
  10. GeeksPhone Keon Screen Replacement: paso 10, imagen 1 de 1
    • Lift the motherboard and remove the connector on the back by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
  11. GeeksPhone Keon Screen Replacement: paso 11, imagen 1 de 1
    • Remove the motherboard from the device.
  12. GeeksPhone Keon Screen Replacement, Antenna: paso 12, imagen 1 de 1
    • Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
    • Unfasten the plastic clamps attached to the antenna.
  13. GeeksPhone Keon Screen Replacement: paso 13, imagen 1 de 3 GeeksPhone Keon Screen Replacement: paso 13, imagen 2 de 3 GeeksPhone Keon Screen Replacement: paso 13, imagen 3 de 3
    • Gently lift the antenna and flip it over to reveal a ZIF connector on the back.
    • Flip up the small retaining flap on the ZIF connector and pull the ribbon cable out.
  14. GeeksPhone Keon Screen Replacement, Screen: paso 14, imagen 1 de 2 GeeksPhone Keon Screen Replacement, Screen: paso 14, imagen 2 de 2
    • Use the metal spudger to gently lift up the back of the screen.
  15. GeeksPhone Keon Screen Replacement: paso 15, imagen 1 de 2 GeeksPhone Keon Screen Replacement: paso 15, imagen 2 de 2
    • Continue to lift up the screen until it is loose from the device.
Conclusión
DavidDrash
Miembro Desde 08/26/15
263 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 3-5, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 189
