Saltar al contenido principal
GeeksPhone Keon Battery Replacement
Qué necesitas
  1. GeeksPhone Keon Battery Replacement, Battery: paso 1, imagen 1 de 2 GeeksPhone Keon Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon Battery Replacement: paso 2, imagen 1 de 1
    • Lift the cover away from the phone.
  3. GeeksPhone Keon Battery Replacement: paso 3, imagen 1 de 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 3-5, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Miembros
12 Guías creadas
4 comentarios
Newer Keon model has user replaceable battery GP-BA002
gintasdx - Contestar
Newer Keon model has a user replaceable battery Li-ion GP-BA002 3.7V 1580mAh .
GP-BA002: Li-ion, 3.7V ,1580mAh, Limited charge voltage 4.2v, with dimensions: 5.1x5.1x0.5cm, its a four pin battery, the pinout es: Negative, BSI, BTemp, Positive, both negative and positive al labeled on the front of the batery the other two not, BTemp is a 10k oms resistor and BSI reads 47k oms on a discharged battery
Diego Gomez - Contestar
Has anybody found another battery that is compatible with the GP-BA002?
ecloud - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 577
