Saltar al contenido principal
GeeksPhone Keon Antenna Replacement
Qué necesitas
  1. GeeksPhone Keon  Antenna Replacement, Battery: paso 1, imagen 1 de 2 GeeksPhone Keon  Antenna Replacement, Battery: paso 1, imagen 2 de 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
  2. GeeksPhone Keon  Antenna Replacement: paso 2, imagen 1 de 1
    • Lift the cover away from the phone.
  3. GeeksPhone Keon  Antenna Replacement: paso 3, imagen 1 de 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
  4. GeeksPhone Keon  Antenna Replacement, Back Plate: paso 4, imagen 1 de 2 GeeksPhone Keon  Antenna Replacement, Back Plate: paso 4, imagen 2 de 2
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
  5. GeeksPhone Keon  Antenna Replacement: paso 5, imagen 1 de 2 GeeksPhone Keon  Antenna Replacement: paso 5, imagen 2 de 2
    • Gently remove the small orange plate by pulling it down.
  6. GeeksPhone Keon  Antenna Replacement: paso 6, imagen 1 de 1
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
  7. GeeksPhone Keon  Antenna Replacement: paso 7, imagen 1 de 3 GeeksPhone Keon  Antenna Replacement: paso 7, imagen 2 de 3 GeeksPhone Keon  Antenna Replacement: paso 7, imagen 3 de 3
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
  8. GeeksPhone Keon  Antenna Replacement: paso 8, imagen 1 de 2 GeeksPhone Keon  Antenna Replacement: paso 8, imagen 2 de 2
    • Lift the backplate away from the device.
  9. GeeksPhone Keon  Antenna Replacement, Antenna: paso 9, imagen 1 de 1
    • Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
    • Unfasten the plastic clamps attached to the antenna.
  10. GeeksPhone Keon  Antenna Replacement: paso 10, imagen 1 de 3 GeeksPhone Keon  Antenna Replacement: paso 10, imagen 2 de 3 GeeksPhone Keon  Antenna Replacement: paso 10, imagen 3 de 3
    • Gently lift the antenna and flip it over to reveal a ZIF connector on the back.
    • Flip up the small retaining flap on the ZIF connector and pull the ribbon cable out.
Conclusión
Michael Moran
Miembro Desde 08/26/15
113 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 3-5, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 159
