Saltar al contenido principal
Gateway W350I RAM Replacement
Qué necesitas
  1. Gateway W350I RAM Replacement, Battery Access: paso 1, imagen 1 de 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I RAM Replacement, Unlocking the Battery: paso 2, imagen 1 de 3 Gateway W350I RAM Replacement, Unlocking the Battery: paso 2, imagen 2 de 3 Gateway W350I RAM Replacement, Unlocking the Battery: paso 2, imagen 3 de 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I RAM Replacement, Remove Bottom Cover: paso 3, imagen 1 de 3 Gateway W350I RAM Replacement, Remove Bottom Cover: paso 3, imagen 2 de 3 Gateway W350I RAM Replacement, Remove Bottom Cover: paso 3, imagen 3 de 3
    • Turn the laptop over to remove the plastic cover.
    • Remove the single 3mm Phillips #0 screw holding on the plastic cover.
    • Use a plastic opening tool to gently pry off the plastic cover.
  4. Gateway W350I RAM Replacement, Removing RAM Chips: paso 4, imagen 1 de 3 Gateway W350I RAM Replacement, Removing RAM Chips: paso 4, imagen 2 de 3 Gateway W350I RAM Replacement, Removing RAM Chips: paso 4, imagen 3 de 3
    • Gently pull the first RAM chip to slide it free from the mounting on the board.
    • Gently pull the second RAM chip, located under the first, to slide it free from the mounting on the board.
Conclusión
Una persona más ha completado esta guía.
Aaron Austin
Miembro Desde 09/22/14
249 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 4-1, Brown Fall 2014 Miembro de USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 10
Todo El Tiempo: 1,783
