Saltar al contenido principal
Gateway W350I Heatsink Fan Replacement
Qué necesitas
  1. Gateway W350I Heatsink Fan Replacement, Battery Access: paso 1, imagen 1 de 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: paso 2, imagen 1 de 3 Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: paso 2, imagen 2 de 3 Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: paso 2, imagen 3 de 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: paso 3, imagen 1 de 3 Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: paso 3, imagen 2 de 3 Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: paso 3, imagen 3 de 3
    • Remove the single 3mm Phillips #0 screw holding on the plastic cover.
    • Use a plastic opening tool to gently pry off the plastic cover.
  4. Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: paso 4, imagen 1 de 3 Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: paso 4, imagen 2 de 3 Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: paso 4, imagen 3 de 3
    • Remove all four 3mm Phillips #0 screws holding in the fan.
    • Remove the tape from the top of the fan
  5. Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: paso 5, imagen 1 de 3 Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: paso 5, imagen 2 de 3 Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Gently remove the fan from the metal housing.
    • Disconnect the cable with tweezers.
Conclusión
Una persona más ha completado esta guía.
Aaron Austin
Miembro Desde 09/22/14
252 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 4-1, Brown Fall 2014 Miembro de USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,061
