Saltar al contenido principal
Gateway W350I Display Replacement
Qué necesitas
  1. Gateway W350I Display Replacement, Battery Access: paso 1, imagen 1 de 1
    • Turn the laptop upside down and position it as shown in the image.
  2. Gateway W350I Display Replacement, Unlocking the Battery: paso 2, imagen 1 de 3 Gateway W350I Display Replacement, Unlocking the Battery: paso 2, imagen 2 de 3 Gateway W350I Display Replacement, Unlocking the Battery: paso 2, imagen 3 de 3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: paso 3, imagen 1 de 2 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: paso 3, imagen 2 de 2
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
  4. Gateway W350I Display Replacement, Separate Plastic Casing: paso 4, imagen 1 de 2 Gateway W350I Display Replacement, Separate Plastic Casing: paso 4, imagen 2 de 2
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: paso 5, imagen 1 de 2 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: paso 5, imagen 2 de 2
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: paso 6, imagen 1 de 1
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
  7. Gateway W350I Display Replacement, Remove Video Cable: paso 7, imagen 1 de 2 Gateway W350I Display Replacement, Remove Video Cable: paso 7, imagen 2 de 2
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
  8. Gateway W350I Display Replacement: paso 8, imagen 1 de 2 Gateway W350I Display Replacement: paso 8, imagen 2 de 2
    • Disconnect the camera connector from the circuit board to completely free the screen.
Conclusión
3 personas más completaron esta guía.
Samuel Newton
Miembro Desde 09/22/14
296 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 4-1, Brown Fall 2014 Miembro de USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Miembros
10 Guías creadas
Un comentario
It was very easy to follow.
Very friendly guide.
Stephan Williams - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,290
