Introducción
In this guide, we will guide you through the process of how to successfully remove and replace the Gateway 1450 Solo's screen.
Qué necesitas
First it is necessary to locate the battery release button. With the laptop orientated so that the screen hinges are facing up the button is located about halfway up the laptop and slightly to the left.
Orient the laptop open to see the keyboard. Have the screen tilted all of the way back for easier access as shown.
Above the keyboard, locate the plastic part containing the power button along with various other command buttons. This needs to come off before you can access the keyboard.
Use the spudger to assist in this step. Using the spudger, wedge it underneath the component.
Once spudger is inserted and pulled far enough, grasp it and firmly, but carefully, pull it out from the left side first
Locate the 2 hinge protectors covering the laptop's hinges.
If not already done while you removed the keyboard, unscrew the screws holding the hinge protectors in place.
