Saltar al contenido principal
Gateway Solo 1200 Battery Replacement
  1. Gateway Solo 1200 Battery Replacement, Battery: paso 1, imagen 1 de 3 Gateway Solo 1200 Battery Replacement, Battery: paso 1, imagen 2 de 3 Gateway Solo 1200 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 347
