Saltar al contenido principal
Gateway Solo 1200 RAM Replacement
Qué necesitas
  1. Gateway Solo 1200  RAM Replacement, Battery: paso 1, imagen 1 de 3 Gateway Solo 1200  RAM Replacement, Battery: paso 1, imagen 2 de 3 Gateway Solo 1200  RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200  RAM Replacement, RAM: paso 2, imagen 1 de 1
    • Locate the RAM compartment on the underside of the laptop near the center.
  3. Gateway Solo 1200  RAM Replacement: paso 3, imagen 1 de 2 Gateway Solo 1200  RAM Replacement: paso 3, imagen 2 de 2
    • Open the RAM compartment by unscrewing the 2 mm screw with a Phillips #0 screwdriver.
    • Once unscrewed, lift off the compartment cover.
  4. Gateway Solo 1200  RAM Replacement: paso 4, imagen 1 de 1
    • Press the silver retention levers on either side of the RAM away from the center of the RAM.
    • The RAM stick will pop up after the retention levers are released.
  5. Gateway Solo 1200  RAM Replacement: paso 5, imagen 1 de 1
    • Pull the RAM stick out of its socket.
Conclusión
5 personas más completaron esta guía.
Addison
Miembro Desde 08/30/19
3,024 Reputación
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 830
