Saltar al contenido principal
Gateway SA1 Wireless Card Replacement
Qué necesitas
  1. Gateway SA1 Wireless Card Replacement, Wireless Card: paso 1, imagen 1 de 1
    • The first thing you need to do is remove the panel concealing the wireless card, by taking out the screws.
  2. Gateway SA1 Wireless Card Replacement: paso 2, imagen 1 de 1
    • Locate the wireless card on the right side of the now removed panel.
  3. Gateway SA1 Wireless Card Replacement: paso 3, imagen 1 de 1
    • Remove the screws in the two possible locations.
  4. Gateway SA1 Wireless Card Replacement: paso 4, imagen 1 de 1
    • After removing the screws, gently pull upwards on the end of the wireless card until it is angled as shown.
  5. Gateway SA1 Wireless Card Replacement: paso 5, imagen 1 de 1
    • Pull the card diretly outward from its socket, all while being mindful of the connected wires.
    • Remove the wired connections by gently pulling them diretly away from the card. Please remember where each one was connected, it will be useful for reconnecting
    • Reconnect wires to new wireless card and screw back into place.
Conclusión
Shawn Cabral
Miembro Desde 03/12/14
463 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 666
