Saltar al contenido principal
Gateway SA1 Cooling Fan Replacement
Qué necesitas
  1. Gateway SA1 Cooling Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Cooling Fan Replacement: paso 2, imagen 1 de 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Cooling Fan Replacement, Cooling Fan: paso 3, imagen 1 de 2 Gateway SA1 Cooling Fan Replacement, Cooling Fan: paso 3, imagen 2 de 2
    • Unscrew the indicated Philips screw.
    • Screw cannot be completely removed from cover.
  4. Gateway SA1 Cooling Fan Replacement: paso 4, imagen 1 de 1
    • Use the spudger to pry open the cover.
    • There will be three tabs on each side except for the side with the screw.
  5. Gateway SA1 Cooling Fan Replacement: paso 5, imagen 1 de 2 Gateway SA1 Cooling Fan Replacement: paso 5, imagen 2 de 2
    • Unscrew the six indicated Philips screws.
    • These screws cannot be completely removed from the cooling fan component.
  6. Gateway SA1 Cooling Fan Replacement: paso 6, imagen 1 de 1
    • Unplug the shown cable attaching the cooling fan to the computer.
  7. Gateway SA1 Cooling Fan Replacement: paso 7, imagen 1 de 1
    • You are now able to remove the cooling fan.
Conclusión
6 personas más completaron esta guía.
Diego Carteno
Miembro Desde 04/15/10
258 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 24-20, Regan Spring 2010 Miembro de Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 13,345
