Saltar al contenido principal
Gateway NV59C66u Battery Replacement
  1. Gateway NV59C66u Battery Replacement, Battery: paso 1, imagen 1 de 1
    • First turn off your laptop, close it, then turn your laptop over exposing the bottom side.
    • Locate the Latches below the battery.
  2. Gateway NV59C66u Battery Replacement: paso 2, imagen 1 de 1
    • Slide the vertical latch upward, unlocking the battery
  3. Gateway NV59C66u Battery Replacement: paso 3, imagen 1 de 1
    • Slide the horizontal latch to the right so you are able to remove the battery from the bottom of your laptop.
  4. Gateway NV59C66u Battery Replacement: paso 4, imagen 1 de 1
    • Now the battery is free. Proceed to lift and remove the battery.
    • Place the old batter to the side, as to not get it confused from your new battery you intend to install.
    • Take your new battery and position it into the battery slot you took the old one out of.
    • Make sure latches are in the unlocked position and apply light pressure on the new battery to make sure it is in place.
    • Put latches in lock position and turn laptop over.
    • Turn on your computer.
Conclusión
Jackson Gandee
Miembro Desde 10/30/19
521 Reputación
4 Guías creadas
Equipo
ETECH Holdings Miembro de ETECH Holdings
Community
2 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 198
